All mileage is in kilometers not miles.
Notes from slip: Street plus track use (22 hours). The diff cooler needs a new temperature sensor so it didn't trigger correctly and the oil did get so hot it vented at the track. Hope it's OK.
Backstory: The diff cooler malfunctioned because after a repair at the body shop it wasn't properly reconnected and the temperature sensor control did not work and I didn't realize it. So, I didn't use the manual override.
