Originally Posted by beanoil
Originally Posted by Donald
Oil changes are not cheap in a diesel engine. I need $80 worth of synthetic oil plus $12 for a filter and then the bypass filter every other oil change.
You are almost there... Being on BITOG, bypass filter, OCD about oil changes. Now we need to get you looking for the bargains that are out there.
Would you believe I just changed my 6.7 PowerStroke oil for 13.00?
And it's a 15w40 synthetic blend with a Hastings filter.....
I only buy the synthetic 5W40 oil for my F250 that I have decided to use. Typically it's Rotella T6 5W40 but did stray with Delo 400 LE due to the CK-4 and Ford spec issues.
I just changed my oil at the 2nd OLM notification with only the filter changed at the first OLM notification. I did a UOA and mailed it. We will see how many OLM notifications I can go on the same oil.
And the vehicle was sprayed today with a oil based rust treatment.
I think with reasonable care of the engine the vehicle will rust out before the engine goes. I am trying to prevent that also.
