Originally Posted by Rmay635703
Originally Posted by beanoil
While E15 on the surface may seem harmless, remember that octane at the pump is the total of all the ingredients in fuel. With ethanol having an octane of 113, you can bet that the base fuel will be dumbed down,(if E15% stays at the regular grade 87) and have more trash in it than ever. If that fuel absorbs water and separates, now you have an 84 octane petroleum product and even more water/ethanol mix. If you fill up regularly, likely no problems. If it sets a while, YMMV. E15 is still not approved for motorcycles, ATV, or OPE.
Because blending octane is non-linear due to vapor point inflection some e10 87 octane mixes are already 84 octane gas + ethanol.
So what you describe is what happened when e10 became standard but...
Part of the reason for e15 is that manufacturers want higher octane specs, even 1 point higher is good for them, we may find the feds standardize to 88 or 89 octane as the minimum going down the road 5 or 10 years.
What's funny is in the 60's and 70's super unleaded could be 95 or more octane, what's old is new I suppose
I've never heard of "vapor point inflection" before. Can you explain this phenomenon further especially with relation to octane?
Toluene for example has a very high octane but a low vapor pressure for gasoline boiling range substances, normal butane also has a high octane rating with a high vapor pressure (volatility) for gasolibe boil8ng range substances, just to name two.
