Originally Posted by Scout1
I agree, Jettas are an attractive option. It would be so much better though with just a little reprogramming of the transmission. Even though sport mode kept the engine running a little bit faster, it would still lug down below 1500 when cruising. That's why I kept grabbing the manual shift to pop it down a gear. In Sport mode, it should keep it up around 2000 I think. That and reprogram it to downshift a bit more smoothly so it doesn't throw your head forward every downshift! It's kinda like having warped rotors as you roll to a stop!
This explains why you got 38mpg on your trip. This car is fully capable of 40+ mpg. These turbo engines develop peak torque from around 1500RPM, precisely the spot the transmission is programmed to operate in. Their bottom ends are built to deal with this, unlike small NA engines. What you perceived a lugging, is normal operation.
