Originally Posted by Corollaman
I've got a basic 2011 Silverado work truck, I know it has ESC because it has a button to turn it off, was traction control standard too? This is a 2 wheel drive single cab. How much, if any will these systems help in the winter? It has new tires and came with two new winter studdless tires on wheels.
Traction control will help keep you from going sideways taking off from a stop, ESC will try to keep your track where you want to go while moving. Neither can defy the law of physics of either crap traction or poor tires and like any system they can't save you immediately.
My first car with ESP ('03 VW Golf) I almost kissed a wall in, had I not had ESP I would have. It was mid-low 30's and had recently rained so roads were damp. 8 mile drive home and no traction issues until I hit the cloverleaf off ramp at my exit and hit a patch of ice and/or oil about halfway through the cloverleaf that sent me into a straight trajectory for the wall. Ramp was under construction so had the concrete barrieriers on each side, despite a good 6-7' clearance off the wall from the start of the slip the ESP did not pull my track together until I was probably well under 6" from my front end kissing the wall.
Great system but don't expect it to defy physics.
