Originally Posted by Snagglefoot
Https://www.Dexostrc.org
I recommend reading the registration manual including the list of the testing required.
Factual and interesting information, Thank you.
But I am more concerned with issues along these lines (considering the significantly lower calcium levels in SN+/D1G2 oils) as the parameters of my engine usage are likely to be 'acid' producing:
With the shifting balance of inorganic to organic acid contamination, it becomes more important to choose the proper tools for the evaluation of lubricants and to correctly interpret the results. In an attempt to demonstrate this issue, three detergent technologies have been compared in a bench test evaluation: A calcium phenate, a calcium sulfonate and a magnesium sulfonate. Three fully-formulated lubricants, identical in every way except for the detergent, were treated with a 5 acid number (AN) of oleic acid, a weak organic acid. In addition, the same amount of acid was added to base oil as a reference case.
Acid Neutralization Test AN Increase (graph did not reproduce - sorry)
As shown in Figure 1, the magnesium sulfonate did not reduce AN at all over the base oil case. The greatest reduction in AN was observed with calcium phenate, but calcium sulfonate also afforded a meaningful reduction in D664 AN. This difference would indicate that the magnesium sulfonate detergent does not completely neutralize a weak acid, thus preserving its BN while allowing the AN to increase and a corrosive environment to be created. Judging the quality of a used engine oil solely on its BN retentional in some cases may not be recommended.
https://www.machinerylubrication.com/Read/354/reserve-alkalinity-oil
