To seal or not to seal that is the ?
twouvakind
Site Donor 2024
Conway SC
Got nice results from my 7424XP, LC white foam's and Blackstone's AIO. I realize there is a built in sealer in the AIO, should I still follow up with a stand alone sealer?
Nope, completely defeats the purpose of AIO you've used. Plus, it won't really bond so the durability will suffer. Just leave it as is and next time use regular polish followed by IPA wipedown and sealant right after
Blackfire One Step is a wonderful product, probably the best AIO on the market. If you're the type to keep it simple, you can use it exclusively.
Id consider a water-bonded SiO2 spray because its so fast and simple. But if the AIO claims that it has a sealant, Id not install a product over top...
Originally Posted by PimTac
Did you mean Blackfire?
Yea, had a UOA on the brain.
I must agree that is a good product, completely satisfied.
No need to, might follow after three washes or so with Blackfire Si02 and as needed to keep the hydrophobicity as needed.
