Originally Posted by The_Nuke
Originally Posted by Serolim
On my 96, from a previous thread I talked about an oil mist getting into my intake from the fresh air hose, how exactly does this hose work?
Just so everyone is on the same page, Let me lay out my understanding of the systems being discussed -
The typical CCV system on most n/a engines will have 2 hoses on the outside:
1) The PCV line which delivers blow-by gases to the intake manifold to get burned with the incoming air/fuel mixture. The PCV valve will usually be on the valve cover of one of the cylinder heads, and it will flow gases out of the engine and into the intake manifold almost 100% of the time (the only time it does not is when the engine is at WOT and producing maximum torque, at which point the PCV valve will slam shut and the flow of gases stops).
2) The fresh air line, aka makeup line, that delivers fresh (filtered) air to the engine's crankcase to replace the blow-by escaping out the PCV valve. Also, t+he normal point of attachment is the air filter air box for the source air, and it will attache to the engine at one of the valve covers to route the air into the crankcase. The air flow almost always goes from the air box to the engine, but when the engine is at WOT and producing maximum torque, the fresh air line can actually reverse flow and deliver blow-by into the air box (and coat the backside of the air filter element).
Now, you said you are getting an oily mist in your intake from the fresh air line, but that seems counter to what I would expect. The PCV line is the hose that runs into the intake, and the fresh air line never touches the intake, only the air box and a valve cover. Did you mean the PCV line when you asked your question?
Would having a filtered breather do the same thing?
Aside from it being burned.
The same as what, coating the inside of the intake with oil? No, it would not,since it would be venting the oily mist into the atmosphere. But doing that is bad for the environment, not to mention it could result in drivablity problems if driven as street-vehicle.
Or is a vacuume being pulled on it?
- The PCV line allows the intake's vacuum to help excavate the blow-by gasses from the crankcase, via the PCV valve.
- The fresh air line (aka Makeup line) allows the vacuum in the air intake box to feed it a steady source of fresh air into the crankcase to replace that gas which is exiting the PCV valve.
Question being because I routed a baffled oil catch can into that tube, and the hose is MUCH longer, about 3 and a half feet. From where it's leading to the can, then back to the intake.
As long as the hose is not being crimped or crushed when you close the hood, it should be fine.
After about a 200 mile drive, mixed hwy/city I checked the can nothing in it. Dry as a bone. So 1, due to the hose being longer the oil part is not making it all the way up, or 2, it's not getting blown into the intake due to the length? Should I be concerned?
Verify the hose is not becoming impassable when the engine is running. Maybe the closed hood puts a crimp in it, or maybe the vacuum inside the hose is too much for the hose to withstand, and it is squeezing flat as a result.
Very informative, but yes here lies my confusion. On the fresh air line I am getting an oil mist in it, and which coats my intake and throttle body.
So my understanding is on high throttle instead of sucking air in it's blowing vapor/oil mist?
So if I unplug it from the valve cover, at idle I'd feel a vacuume, and at high throttle a pressure?
I can't figure out how to post pics to the forum from my iPhone or I'd show it. But if u google a picture of the 5.7 96-98 vortex you can see the line on the passenger side. It goes from the valve cover to the near end of the intake, close to the silencer box area on top of throttle body.
