Originally Posted by Snagglefoot
Working backaward from 51 kwhrs, the pump was on for 12 hrs/day x 14 days = 168 hrs. 51 kwhrs/ 168 hrs = 0.3 kw. 0.3 kw x 1000 w/kw = 300 watts.
P = IV. 300 watts/ 120 volts = 2.5 Amps
So, if your pump is 2.5 Amps, the measurement is correct. If you want to believe 17 kwhrs, your pump is only 2.5/3 = 0.8 Amps
Judging from the sizeable plume, I'd say your pump is 2.5 Amps, your present 51 kwhr reading is correct and you were previously getting a free ride.
Go ahead and burst my bubble why don't you ...
I suppose this is what could be going on. I've no idea the power rating on the Kasco, it's an older model I bought used for $100 off the developer of the subdivision (they sell new for $1499.00). It was fresh off of a repair shop service and checkup and given a clean bill of health and fresh oil (oil bath type motor and bearings). So it should be running to spec, I just don't know what the spec is. Of course, now that I've said out loud that it's running fine, it will probably cr@p out tomorrow ...
P.S. meter is on Residential Service rate as it is on my lot and bill addresses to my house. Used to be the HOA covered bill. HOA was dissolved and so with 1/2 the pond on my lot, 1/2 on the neighbor's lot we split the operational cost.
