I'm using both the Pirelli Cinturato P7+ and the Michelin Premier size 205/55-16 H rated on two Subaru Imprezas.
The Pirelli is quieter and smoother riding. The Michelin is much better on wet roads and handles better on dry roads.
Great info, I appreciate this.
Just a question: are Michelins noisy in absolute values? I mean would you call them loud without comparison to P7+? How long are you using them?
The Michelins are just slightly louder than the Pirellis. Not something you would notice unless you heard them back to back. I would add
that there is one concrete bridge I use that makes the Michelin sing, not something I notice as much with the Pirellis.
Kind of hard to describe but the Michelins just seem to run with good sense of straight ahead on the interstate.
Been using the Michelin Premiers since 2015 and have around 24,000 miles. The ride that felt harder than I expected seemed
to soften up after a few thousand miles. The Pirellis have only been in use for one year and about 14,000 miles. I hope this rambling explanation helps with your decision.
