tony1679
Thread starter
Originally Posted By: Rand
For all intents and purposes The G4 Pro and the htr a/s P02 are the same.
Just like when you buy a club version of a popular tire.
You can with confidence read reviews on either tire.
There is attention to detail.. and there is lack of common sense.
for example if you purchase either of those tires in a wider size the difference from the same Brand of tire far exceeds the differences between the 2 different Brand tires in the same size.
And both are better than the ziex 950.
"For all intents and purposes, the G4 Pro and the htr a/s P02 (and the ZE950) are the same." Common sense would tell me if you are calling the G4 and the P02 the "same" then you should also call the Ziex ZE950 the "same." All three have almost identical tread patterns, but for some reason the ZE950 isn't up to par with your "common sense." I also don't understand your alternate/wider size statements. I am only buying one size, therefore I am only looking at tread patterns of one size. This is irrelevant.
But please explain why you are arguing that they are the "same" but the ZE950 is somehow different and inferior...
