The diodes can be bad but not show up in AC ripple but show up when the car is no longer running. That's why disconnecting the alternator over night would for sure rule it out.
I've seen diodes do weird things based on temperature. They operate fine when say room temperature to warm, but when they get cold or overly hot they start passing current the other way. It's like they are on the edge of failing and just need that nudge to push them over the edge. That being temperature.
Keep in mind they spend their life being beat up by continuous heat cycles.
