Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
38 registered members (97K15004WD, CC1981, 69Torino, bbhero, Char Baby, 5 invisible), 943 guests, and 38 spiders.
Topics295,207
Posts4,929,904
Members66,711
Most Online2,553
Oct 27th, 2018
Having tires installed on chrome wheels #4894598
10/12/18 09:30 AM
10/12/18 09:30 AM
OH
grampi Offline OP
grampi  Offline OP
OH
When you have tires mounted on chrome wheels, do you make sure the installer uses plastic tire irons so they don't scratch the chrome?
Re: Having tires installed on chrome wheels [Re: grampi] #4894612
10/12/18 09:44 AM
10/12/18 09:44 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I take a video when I get out of my car showing the store I am at, each wheel is free from damage, and then walk inside to hand the keys off. I also mention that the wheels are a optional factory chrome wheel to the person I hand the keys to. When I get the car back I inspect each wheel carefully.
I have the highest optional wheels on my Q50s so I will have to do this as I need 2 tires installed soon. I rather they think I am a a-hole then give my car to the newest kid to mess up my wheels.
Almost forgot. I also take video showing the dash showing each wheel sensor is working in good condition. Thats one some tire shops will try to say it was that way before you got there.
yup
Re: Having tires installed on chrome wheels [Re: Jimzz] #4894613
10/12/18 09:51 AM
10/12/18 09:51 AM
Indianapolis
redllama9109 Offline
Indianapolis
Probably good to thing to do.
Re: Having tires installed on chrome wheels [Re: grampi] #4894678
10/12/18 11:15 AM
10/12/18 11:15 AM
California's Wine Country
SLO_Town Offline
SLO_Town  Offline
For all of my cars I always use the same guy at the same tire store. Way back, I actually "interviewed" the tire store. I explained my expectations and had them re-assure me that they were capable of doing what I was asking.
In order to facilitate a proper job, I R&R all the wheels and thoroughly clean them and remove the existing stick on weights (including the foam backing and residual adhesive). For my "preferred" cars I take my wheels in "loose".
I set expectations thoroughly, including the new wheels weights are properly aligned (and not cocked). I have them calibrate their balance machine before they balance my tires. And, of course, absolutely no rim gouging.
To further set my expectations, I remain there until the job is complete and I tip the installer $20 per wheel - TWENTY DOLLARS PER WHEEL. I inspect each wheel as they are done. My tire store knows me well. We have a mutually beneficial relationship.
Scott
03 BMW 330Ci (Euro Castrol 0W-30)
10 Honda Element (Kendall GT1 Max 5W-30)
11 BMW 328i (Euro Castrol 0W-30)
16 VW Passat 3.6L SEL Premium (Euro Castrol 0W-30)
Re: Having tires installed on chrome wheels [Re: grampi] #4894687
10/12/18 11:32 AM
10/12/18 11:32 AM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Mechanic here:
Never seen a plastic tire iron. We had a different machine we'd use for alloy wheels, spray painted ones, or anything else where scuffs are a concern. It's a touch-less machine - it secures the wheel through the lug holes, and centers it with a plastic cone through the center. The arm that would swing down to break the bead is plastic, and the "duckbill" that would do the mounting/demounting was plastic lined, with its own pneumatic tire iron built in. Through the whole process, the only pieces that would touch the wheel are the tire itself, and the mounting through the center.
Your best bet, IMO, would be to call to either tire shops to dealers that are used to dealing with higher end products. They'll be better equipped to meet your expectations
It was a slightly older version of this
https://www.youtube.com/watch?v=HVStKTsglPA
2005 Tahoe - 135k
2003 Forester(the swagger wagon) - Rehomed
1999 Passat - Rehomed
Re: Having tires installed on chrome wheels [Re: grampi] #4894742
10/12/18 12:41 PM
10/12/18 12:41 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Chrome shouldn't scratch. Its aluminium that gets gouged
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Having tires installed on chrome wheels [Re: grampi] #4894756
10/12/18 12:56 PM
10/12/18 12:56 PM
WA
SnowDrifter Offline
SnowDrifter  Offline
WA
Quality chrome shouldn't. But there's enough cheap chrome out there, I think it's a valid concern
2005 Tahoe - 135k
Re: Having tires installed on chrome wheels [Re: SLO_Town] #4894764
10/12/18 01:04 PM
10/12/18 01:04 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Scott
I was going to suggest bringing the wheels in but you took it to an entirely different level! Bravo, sir!
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Having tires installed on chrome wheels [Re: grampi] #4894802
10/12/18 01:45 PM
10/12/18 01:45 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
I had a "touchless" shop mount tires on my Volvo wheels. They gouged paint off the rim of every wheel.
They bought me a new set of wheels.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Having tires installed on chrome wheels [Re: maxdustington] #4894840
10/12/18 02:30 PM
10/12/18 02:30 PM
SLO_Town Offline
SLO_Town  Offline
Bravo? Bravo!!?? Thank you! My wife thinks I'm OCD!
Scott
Re: Having tires installed on chrome wheels [Re: grampi] #4896794
10/15/18 06:55 AM
10/15/18 06:55 AM
OH
grampi Offline OP
grampi  Offline OP
OH
I've seen chrome scratched on many wheels, so chrome does in fact scratch, and it doesn't happen only to cheap wheels. I just don't know what they doing to scratch them....I just want to make sure the wheels I have don't get damaged in the process of installing tires...
