Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
104 registered members (2018matto, 28oz, 1foxracing, 64bawagon, 01ws666, aba4430, 9 invisible), 1,858 guests, and 45 spiders.
Topics294,973
Posts4,925,157
Members66,657
Most Online2,553
Oct 27th, 2018
2017 Altima extended oci #4894343
10/11/18 09:59 PM
10/11/18 09:59 PM
Illinois
cals400ex Offline OP
Illinois
I have a 2017 Altima 2.5. I’m looking to go as long as reasonably possible using an “off the shelf” synthetic oil (Mobil 1, Pennzoil, etc.). What is generally considered the longest you should on an oil change with these oils? 7.5k miles? 10k miles?
Re: 2017 Altima extended oci [Re: cals400ex] #4894346
10/11/18 10:12 PM
10/11/18 10:12 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
10k is good normally but you'd first want to do a UOA to see if it can be stretched that long. So do UOA at say 6k and take it from there. Seems like you are under warranty so play it safe and follow OLM.
Re: 2017 Altima extended oci [Re: cals400ex] #4894393
10/12/18 01:13 AM
10/12/18 01:13 AM
Southeastern USA
FowVay Online happy
FowVay  Online Happy
Southeastern USA
Your owners manual states to change the oil and filter at 5,000 mile intervals under normal use conditions using 0W-20 oil. I have a Frontier pickup with the QR25DE engine and it also states to change the oil and filter at 5,000 miles except to use 5W-30 oil. No manufacturer specific specifications are called for, just the normal API SN and ILSAC GF-5. These engines seem to shear oil rather quickly and have a very small filter. For longevity I chose not to try to extend my drain interval past Nissan's recommendations.
Don't forget to follow the other maintenance requirements in the manual which include brake fluid at 20,000 mile intervals, cabin air filter at 15,000 mile intervals and engine air fiilter at 30,000 miles. The cabin air filter isn't going to increase vehicle life but the oil and brake fluid changes and engine air filter replacement certainly will.
Re: 2017 Altima extended oci [Re: FowVay] #4894443
10/12/18 05:00 AM
10/12/18 05:00 AM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Very good post here. My Nissan Altima VQ has 245k miles on it and is kicking rear end still : )
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 2017 Altima extended oci [Re: cals400ex] #4894459
10/12/18 05:53 AM
10/12/18 05:53 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Stick with Nissan's oem recommendation. Don'y buy into the oil makers' silly extended oci stuff.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: 2017 Altima extended oci [Re: cals400ex] #4894496
10/12/18 07:36 AM
10/12/18 07:36 AM
Illinois
Illinois
Since I’ll be under warranty for ~6 more months, I’ll follow the manufactures recommended oci. After that, I may try an uoa and try to extend the oci, if possible....I’m just trying to avoid getting an oil change ever two months if I can.
Speaking of brake fluid, why does it need changed so frequently?
Re: 2017 Altima extended oci [Re: cals400ex] #4894644
10/12/18 10:44 AM
10/12/18 10:44 AM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Brake fluid is hygroscopic - it absorbs water. Water lowers the boiling point of the fluid.
Regular brake fluid service is probably the most neglected service.
On a vehicle that is neglected, a brake fluid flush will give you a better pedal.
Re: 2017 Altima extended oci [Re: cals400ex] #4894648
10/12/18 10:46 AM
10/12/18 10:46 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
I wouldnt push it with these cars and their tiny filters. 5-6k max on good syn.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 2017 Altima extended oci [Re: cals400ex] #4894660
10/12/18 11:03 AM
10/12/18 11:03 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I would't go past what the manual calls for on the filter unless you want to change the filter and keep going on the same oil because they are such small filters usually on Nissan vehicles. I would also use at least one oil analysis to determine safe OCI for the oil.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: 2017 Altima extended oci [Re: cals400ex] #4894866
10/12/18 03:12 PM
10/12/18 03:12 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Plus, the (bigger) Honda filter fits. That's what I use.
Re: 2017 Altima extended oci [Re: JeffKeryk] #4895022
10/12/18 06:33 PM
10/12/18 06:33 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Just for my own info, does the technical specs match on both filters? Eg: the flow rate, maximum PSI, bypass etc. ?
Re: 2017 Altima extended oci [Re: cals400ex] #4895048
10/12/18 07:01 PM
10/12/18 07:01 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have been doing 10K OCIs for 40 years with various M1 oils in several different types of engines. Never a problem, and I don't waste money on UOAs.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2017 Altima extended oci [Re: StevieC] #4895177
10/12/18 09:42 PM
10/12/18 09:42 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
Dunno that much about it; sorry StevieC.
Did a quick look on Fram website, compared XG6607 AND XG7317.
By Pass Valve is both 13.
The gasket size is slightly different.
The 7317 was used on earlier Nissans, both 4 and 6 cylinder.
Re: 2017 Altima extended oci [Re: StevieC] #4895215
10/12/18 10:51 PM
10/12/18 10:51 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
No, because one is oversize, so it's a bit longer. Just ribbing you, Stevie. wink Yes, they're pretty much the same, at least for the Wix filters, and probably across the board. Nissan actually specs the longer filter for a few of their applications, notably the V8s and some of the 3.5 varieties, depending upon the install, and a bunch of other seemingly random applications.
I use the oversize on occasion, since it gives me a silicone ADBV with the Wix and is actually cheaper. The quick lubes give everyone the shorty because they want to consolidate inventory (I've never seen where the long one wouldn't fit) and only dealers and shops are allowed to go out of spec, not us lowly mortals. As I mentioned in the filter subforum, on these engines, Wix actually has four that will fit it, and I've tried them all with no problems. Wix changed the base plate, with the 51358 being the short one, 56356 being the long one, 51365 being the original short and 51356 being the original long.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: 2017 Altima extended oci [Re: cals400ex] #4895300
10/13/18 05:56 AM
10/13/18 05:56 AM
Illinois
Illinois
Does the longer filter provide any benefit? Maybe if one were wanting to extend their oil change interval?
