New version of Winamp released
by Jimmy9190. 10/23/18 11:07 PM
Need turbo help
by Dylan1303. 10/23/18 11:06 PM
Friction Modifier
by ant. 10/23/18 10:50 PM
Where does the rock auto discount code go?
by DONWATERS. 10/23/18 09:20 PM
Paul Bunyan Trail - Crow Wing extension - Day 2
by Number_35. 10/23/18 09:20 PM
Itasca State Park - bike loop - Day 4
by Number_35. 10/23/18 09:14 PM
Scan Gauge II X-Gauges
by StevieC. 10/23/18 09:08 PM
Paul Bunyan Trail - short and steep - Day 3
by Number_35. 10/23/18 08:58 PM
by Number_35. 10/23/18 08:47 PM
I put 15W40 in my L83 Ecotec
by Realtech214. 10/23/18 08:22 PM
Burning off fuel dilution?
by Spetz. 10/23/18 07:19 PM
Clear Headlight Cover Correction?
by legandrex. 10/23/18 07:02 PM
FEDERATED PG 2500F CUT OPEN
by 53' Stude. 10/23/18 06:53 PM
Found a video on 6F35 disassembly
by SirTanon. 10/23/18 06:10 PM
Outboard oil safe to use in lawn mower?
by Jack2468. 10/23/18 05:43 PM
My Latest Purchase: 95 Chevrolet K1500
by dogememe. 10/23/18 05:05 PM
shaguar_ex_type, WmMaroon, hogan646, hermie, avatar299
66282 Registered Users
55 registered members (bbhero, ant, anndel, beanoil, 9 invisible), 1,041 guests, and 34 spiders.
Topics292,449
Posts4,879,691
Members66,282
Most Online2,494
Oct 17th, 2018
Additive Instructions #4894260
10/11/18 08:45 PM
10/11/18 08:45 PM
Ocean Pines, Md.
Jack2 Offline OP
Jack2  Offline OP
Ocean Pines, Md.
Almost all additives such as Techron, PRI-G etc. say to add the additive and then add fuel to proper proportion. [1oz per each 16 gallons for instance.]. I get that since the idea is to be sure the additive is thoroughly mixed with fuel being pumped into to tank. HOWEVER, I constantly find myself wanting to add the additive after car is fueled up or shortly thereafter for various reasons. It might be because my wife got fuel and I was not with her or I want to wait until the fuel is used to the point where the proportion of additive to fuel is correct etc. Anyway, is there a problem adding an additive to a partially filled tank in ones garage for instance? I would think that a few quick braking actions shortly after adding would mix the additive well enough. Would appreciate any opinions.
Re: Additive Instructions [Re: Jack2] #4894262
10/11/18 08:49 PM
10/11/18 08:49 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Normal driving and a few stops will mix the additive with the fuel in short order.
God Bless Our Troops
Re: Additive Instructions [Re: Jack2] #4894263
10/11/18 08:49 PM
10/11/18 08:49 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
It's fine and it will mix, just maybe not right away like right that minute, Nothing to worry about.
'18 Dodge Grand Caravan GT - AMSOIL SS 0w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Additive Instructions [Re: Jack2] #4894271
10/11/18 09:04 PM
10/11/18 09:04 PM
The land of USA-made Subies!
SubieRubyRoo Online content
SubieRubyRoo  Online Content
It will eventually all go thru the injectors one way or another...
Re: Additive Instructions [Re: Jack2] #4894309
10/11/18 09:44 PM
10/11/18 09:44 PM
New England
gathermewool Offline
New England
At what level does the fuel filler neck enter the fuel tank?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter
Re: Additive Instructions [Re: Jack2] #4894378
10/12/18 01:36 AM
10/12/18 01:36 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
As others have said, the additive will mix with any amount of gas in the tank regardless of when you put in the additive. However, the only concern that I can think of is that...
...some gas tanks have a spring loaded check valve at the tank where the filler neck goes in. And the additive may just sit in the filler neck. It takes the force of the gasoline being pumped in, in order to push open that check valve. IDK if these check valves are still being used today.
I had a Honda Accord with an OE gas tank check valve. I never knew this until years later when I had to replace the gas tank. However the replacement tank did not have the valve.
Just something to consider.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Additive Instructions [Re: Jack2] #4894952
10/12/18 06:17 PM
10/12/18 06:17 PM
Ocean Pines, Md.
Jack2 Offline OP
Jack2  Offline OP
Ocean Pines, Md.
Appreciate the replies. I have a 08 Jeep which has a spring loaded piece at the top but I would not call it a check valve. In any case it has fallen into the tank long ago. Our CTS has no fuel cap, just the push open plastic valve at the top. I don't think either of these acts to trap an additive. This is the first I have heard of a gas tank check valve as you describe. Was this more related to Japanese vehicles or did I just not notice this valve in other cars?
Re: Additive Instructions [Re: Jack2] #4895283
10/13/18 05:44 AM
10/13/18 05:44 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Well, unless you've dropped the gas tanks for repair/replace in other vehicles, you couldn't/wouldn't possibly know.
Those who have issues with the gas pump constantly clicking off while filling the vehicles with gas, may in fact have that check valve that I speak of. I could never fill this particular Accord without issues. It was bad in the cold winter as it took longer to fill. I just couldn't hold the handle/trigger at full blast when filling like with other vehicles that I've owned
2 yrs ago, I dropped the gas tank in my daughters 2006 Mazda3(which she recently sold) for repair. It DID NOT have the check valve and did not have any issues filling the tank. But, I've had issues over the years with other vehicles but, never had to drop the tank so, who'd know?
Most likely you don't have this check valve in your vehicle however, I think it's best to put in the fuel additive/injector/intake valve cleaner FIRST for the reason that I mentioned.
"Retired"
'15 Honda Civic LX
