A little quick math.
The Tesla model 3 is about 300 watt hours per mile in normal use.
The noon sun, when directly overhead, such as in the tropics, equals 1000W energy, much of which is heat energy.
High end conformal solar arrays can now reach 20% eff.
SO, each square meter of properly positioned solar panel, with the sun hitting it 90 degrees, can produce 200W (only at noon) .
A Tesla model 3 has about 2 sq meters of area on roof, hood and trunk. A well optimized setup could achieve a few extra miles range per day.
That said, if you park your solar Tesla in long term parking at the airport for a week, instead of coming back to a battery that is a touch lower than when you left, you may have 20 additional miles range.
