A non-mechanically oriented friend was talking to me about doing some maintenance on his 7 year old mower for the first time
since it's hard starting (6-7 pulls) and he thinks that the oil should probably be changed some time.
We talked about oil changes, what oil to run, filters, plugs, carbs, sta-bil and all that stuff. He reports that it's a Tecumseh engine and that it says to use 30W and NOT 10W30.
What's the deal with recommending against 10W30 in all conditions? Is this assuming dino oil and hoping for better thermal stability in extended drain with plain 30W? He referring to "topping up", so there's consumption, but I'm not sure how much.
I'd really rather see him use a synthetic 10W30 or 10W40 if he has serious consumption. He's not a gearhead so I suggested Walmart Tech2000 or whatever it's called if price is a big deal.
Is there a real reason not to run 10Wxx in this engine?
Craig.
Craig.
