Only thing I did today was change the oil and filter and change the nasty air filter.
Tomorrow I'm going to see if any crud ended up in the MAF sensor from when I changed the air filter.
If it's not a MAF issue I'd say the only other things are fuel delivery issue, o2 sensor, or vacuum leak right?
It drives ok but it seems a bit unhappy. Earlier I was trying to merge into a busy road from my apartment and the Escape hesitating badly for several seconds was not safe. But it didn't set the code until hours later while it seems to be driving ok.
