Flushed/changed brake fluid for first time in my life this fall on 2008 Harley Road King (no ABS). Bought a mityvac (8100 I think) at harbor freight with a 25% off coupon. Used the tip that goes to a point and stuck that into the bleeder end, worked like a charm. No air introduced during bleed, worked like a charm, highly recommend this method. Better yet if you have someone else to keep the master reservoir filled. I had to bleed open bleeder, let it drain for 10 sec or so, then close valve and keep reservoir filled myself so some back and forth involved.
