It's a 1957 or so. Has no pcv system. Just a breather where you put the oil in. The top end was pretty dirty when I replaced the valve cover gasket and adjusted the valves last year. I don't have a lot of hours on it since then but I wanted to get what was loose out.
Plus the oil filter is a bypass filter only. Ran it a couple hours this morning in the heat then immediatly after shutting it off pulled the plug and drained it hot.
It got a fram filter and Napa 15w40.
