Hi, first time poster, long time lurker. I've tried to research as much as I could before posting, so help me learn!
[Preface]
Recently purchased a 2013 Scion FR-S for double duty use as a daily and a frequent autocrosser. Factory fill for the transmission, I believe, calls for a 75w90 GL3.
Trying to research which fluids would be best to use in this car. I'm finding many people have frustrations with the transmission when the fluid cold, and that gears are harder to go into, and sort of grind if you force it. I'm finding this to be true, but as the fluid heats up, it goes away.
The fluids that are recommend to me by a popular local tuner (and by others on FT86club) are Motul 300 and Pentosin MTF2.
[Questions]
The pentosin is frequently recommended for colder temperature locations (I'm in the PNW, so not terrible) and I have read it eliminates those issues... However, after emailing CRP Automotive, the MTF has been discontinued as of 2 years ago.
I found the Dedicated MTF Fluids list, and see that it's sorted by Kinematic Viscosity.
1. Are there any other factors to consider besides Kinematic Viscosity when choosing a gear oil?
2. Since Pentosin is rated at 7.0 to 7.5 cSt@100C, and Motul is rated 15.2 cSt@ 100C, does that mean I would be safe choosing any of the fluids between those ranges on that list?
Thanks in advanced!
[Preface]
[Questions]
Thanks in advanced!
