Looking for a new carburetor for 2002 honda 90cc
Kershaw,SC
My original carb went out in about two years- leaks at bowl, I tightened it but it still leaks.
Where to get a new carburetor for my 2002 honda 90cc?
I find a cheap carburetor from Hexautoparts under $15 with free shipping.
I know chinese atv carburetor replacement cost is not expensive,is it okay to order this one ?
Any recommendations ?
Thank you.
Take off the bowl and check to see if it is flat those pot metal bowls warp and develope leaks between the screws. tape some fine sandpaper to a flat deck top and sand it down to make the seal surface flat again.
I've used Chinese aftermarket carburetors but the supplied fuel / vacuum lines suck. Make sure you get some good fuel lines to go on it.
