I just finished rebuilding a couple of model airplane engines that were so gunked up with varnish they could barely turn. In order to avoid having to do this in the future I was wondering if there is an after run oil I could use to reduce or eliminate this.
The engine burns glow fuel: approximately 25% oil, 10% nitro and 65% methanol.
The ideal after run oil would likely have a low viscosity with an additive package designed to clean out the engine and eliminate residue. But also to burn clean for the next time the engine is used.
Any specific recommendations? Would ATF work? And due to the requirement for the after run oil to burn clean, are synthetics still viable?
