I just changed the oil in my Audi (UOA posted here) which got me looking into the VW502.00 and VW504.00 approved oils; both are suitable for my car but the 502 is not approved for "variable service" i.e. if you want to run the car beyond a year. I intend to change at least once per year so I changed out the factory fill to Fuchs 5W30 with VW502.00 approval.
Below is a table of some of the approved oils with their respective approvals and the TBN specified in their data sheets. As you can see all of the VW504 approved oils meet the ACEA C3 specification and the large majority of the VW502 oils meet A3/B4 specification. However, there are a few VW502 oils that meet the C3 spec e.g. Total Quartz Ineo MC3 and Valvoline SynPower MST C3.
The VW504 oils have TBNs typically in the mid 6s while the VW502 oils are all above 7 and many over 10 as required by A3/B4 spec (although I highlighted a few exceptions in red)
My question for the forum is why would the VW504 oils with notably lower TBNs be considered "longer life" (i.e. variable service) than the VW502 oils with higher base numbers? PS I'm new here.
