Hi guys,
I want to do a UOA to determine the health of the engine, whether there are signs that it has limited use left and to see if my OCI is right.
I've found a tester that checks these values
Analysis
Aluminium (Al)
Copper (Cu)
Chromium (Cr)
Iron (Fe)
Lead (Pb)
Tin (Sn)
Contaminants / Additives (ppm)
Silicon (Si)
Sodium (Na)
Physical Tests
Water (% by crackle)
Viscosity (cSt,40°C)
PQ Index
Fuel
Will this be sufficient for my needs or is it missing something?
Analysis
Aluminium (Al)
Copper (Cu)
Chromium (Cr)
Iron (Fe)
Lead (Pb)
Tin (Sn)
Silicon (Si)
Sodium (Na)
Physical Tests
PQ Index
Fuel
