Not directly related, but I test drove a used Honda Insight, 2002 if I recall . I got it on a back road and hit 90 indicated and it had a little more speed left, but I ran out of courage. Which was a good thing, because on closer inspection the front tires were both worn to the steel belts. He said the oil was freshly changed in the last 100 miles,and had receipt to prove it, but the dipstick and fill cap said otherwise, so I passed. It was a very slippery little car at speed. I always wondered what the tested top speed was in that car.
