This is all new to me. I thought the pre- tensioner device was a pendulum or some kind of accelerometer. I've had my seatbelts lock up in hard braking.
I've always heard it called an "inertia reel."
My 1970 MG doesn't have one-the shoulder belt fastens to the back deck of the car(it's a bit of a pain, as you have to unhook and rehook it every time you put the top up or down) and you're supposed to adjust the belt until it holds you "snugly." Even though it's inconvenient, I actually kind of like it as it makes me feel very secure in the car, although it's obviously a pain if the car regularly has different drivers and/or passengers. Since my girlfriend is about the only one to ever ride in the passenger seat, it stays adjusted to her, and it can be a bit of a learning process for someone to figure out how to both adjust and buckle it). MG only used the fixed shoulder belt design for a few years-they added an inertia reel maybe in '72 or '73(and changed the mounting point to the rear wheel well rather than the back deck).
In any case, the pretensioner is a LOT faster than the inertia reel. The inertia reel only reacts to you suddenly pulling the belt out, while the pretensioner acts hopefully before any significant movement occurs in an accident. They are a one shot deal, and you will KNOW if one has gone off. Aside from the seat belt not retracting, the ear closest to it will probably be ringing and your shoulder will probably be sore the next day.
I hope I don't have to experience that. I'm deaf in my right ear so I don't need any other problems.
