Can you guys help me find the source of a slow power steering fluid leak? I'm assuming I have one, because my PS line and hose looks to be wet, from where the metal line connects to the pump to about 8 inches along the hose. I've put in pictures, but I'm not sure if you can tell in them that the metal is oily. It is. I know you can tell in them where the hose is oily and where it is dry. Is it possible to tell from this where the leak most likely is? I am planning to clean it off and watch it to see where it starts, but I think this is a really slow leak and so that might take a while. As for cleaning it off--what is the best thing to use for that? I assume pretty much any degreaser will do the job on the metal, but what works and is safe on the hose? Thanks!
(The first picture is from the back side relative to all the others)
