This Purple Plant Has a Secret That Could Replace Synthetic
WI.
replacement
After the fatty acids were discovered, they were sent off to the University of North Texas for further study. There, the scientists found a new use for them: They work spectacularly well as a lubricant. The oil works similar to castor oil, but more efficiently at high temperatures. While castor oil can become gummy in engines, the violet cress oil has less of a tendency to do this. In theory, this could pave the way for breeding violet cress to use its oil to replace petroleum or synthetics as a lubricant in engines. (Like castor oil, it's unlikely to be used as a cooking oil because it will, uhh, move right through you.)......
