I started the jeep up and it is running real bad missing. I checked the voltage output and it is at 16+ volts, I understand that the voltage regulator is in the PCM not in the alternator also the battery gauge stopped working and it reads check gauges no engine light is on. I used it last week at it ran good. I am thinking that the PCM went bad?
