I just purchased a new John Deere LT160 with a 16hp Kohler single. I'm going to use JD 10W-30 for the first change at 5 hours. I debating to try GC 0W-30 or stay with the JD 10W-30. Any advice?
If there is some reason you don't want to use a syn-lube, why don't you give one of the oils you mentioned in 15w-40 a shot?quote:
Originally posted by Brett Miller:
If I could find Long Life, Delvac 1300 or Delo 400 in 10W-30, I would use it.
Yes, I know.quote:
Jelly,
I believe GC is a "syn lube"
