Originally Posted By: ram_man
Originally Posted By: Rand
Originally Posted By: rooflessVW
Here you go!
That car also has almost 50% more displacement and its a dyno tune not a canned tune.
I think 40hp is by far the max you would get with a canned tune. on a 1.4L Turbo
anything more and you would be either blowing up motors without dyno tuning or would run like total poo.
IIRC stock it is 160hp engine hp NOT "to the wheels" so getting to 200hp on the dyno would take some mod support to go with the tune.
Engine is 184 hp stock about 150-160 to the wheels
That's a rather broad range, but if we go by it, the average results in about 18% drivetrain loss (155HP to the tires), if we continue with that figure then your 230whp results in ~270HP flywheel, which is almost 100HP gain, in an engine with a displacement of 1.4L, which means factory it is already at a very high density of 131HP/L and we are increasing it to 193HP/L, which is ridiculously high.
Compared to rooflessVW's example, which is the Mark VII Golf with a 2L engine producing 217HP stock (108HP/L) and the aforementioned 80HP gain, that puts it at about 300HP flywheel, which is 150HP/L. That VW would need to produce 386HP to match our 193HP/L figure.
I'd be concerned about it staying together at that power level.
