Can anyone recommend where I can find marine grease other than the from manufacture Quick-silver(mercury)
The greases I need are as follows: 2-4-C Marine lube # 92-825407a12(propeller shaft), Gimblebearing Lube #92-8250552a2(Bearing lube), Special lube 101 92-13872a1(steering lube). Suggestions on substitute welcomed.
