Bob and blano: Sorry, gents. We're not communicating here. That's ok.
I agree with you both on the water thing - if it's leaking lube, it'll take-on water. No trouble here. And the water will settle out eventually, and the stuff below the water line will be, well, below the water line. Gravity works.
I go back to my earlier posts where I said that a 50/50 mix should not be the norm for a lower unit. It should be water tight, or fairly close, if it's in good repair. If you recall, my primary criticism was on the validity of the test. If 50/50 mixes of oil and water should NOT be common in lower units, why should one put any stock in a test that demonstrates these conditions?
I ask again for a test with lube greater than 90% and water less than 10%. I think the test results would change.
I've been amazed by the coating ability of the products from Superior - especially when the engine has been stored for a while. Some of their lubes remained on the metal surfaces a year after the engine was shut down.
On this test and others - including the hand-done Timken tests - I have this comment: Physicists, parapsychologists, and kinesiologists agree that the beliefs of the person conducting the experiment will change the outcome of the experiment. Physicists find that people searching for subatomic particles find more of them when they believe they’ll find them, those that don’t believe don’t see them. Same as when our spouses ask us to get the mustard from the fridge and we don’t want to. It’s on the door in front of us but we don’t see it. That’s also why these and other disciplines use double and triple blind tests.
I wouldn’t trust someone to use the same manual force on the Timken machine when he or she knew the oils in each test, and had a favorite. Even if consciously wanting to keep things as even as possible, you can’t outrun your beliefs.
We see this when someone chooses a test they know will make their product look good. We also see this when, even when given volumes of test data that proves that one product is better than another, the person still can’t see the results for what they’re worth.
There’s a story about early Australian natives that came to the city for the first time. They had never been, but knew about the existence of cars and horse-drawn buggies. They looked both ways, started across the street, and were run down by bicycles. They had no idea what a bicycle was - AND COULDN'T SEE IT - until they had tire marks across their foreheads. (True story, BTW.)
Run it again with less than 5% water and let’s see the nails. If the AMSOIL nail is still rusty, I'll drop the subject.
Andy
EDIT: Bob, I looked again at the pictures of the nails you posted. Kinda blury, but they don't look like plain steel nails. They look coated - cement or zinc? And what are the smear trails around the Schaeffers nail?
[ January 23, 2003, 10:03 PM: Message edited by: Andy H ]
Andy
