Dyson Analysis vs. Blackstone VOA of Elf Excellium LDX 5W-40. Samples from same 1L bottle were sent to Dyson and Blackstone for analysis.
1st column Dyson / 2nd column Blackstone
Iron 3 / 0
Copper 0 / 0
Tin 0 / 0
Lead 0 / 0
Chromium 0 / 0
Nickel 1 / 0
Aluminium 1 / 0
Titanium 0 / 0
Silver 0 / 0
Calcium 1098 / 1143
Magnesium 977 / 969
Zinc 1032 / 905
Phosphorus 980 / 813
Barium 5 / 0
Molybdenum 0 / 1
Silicon 3 / 3
Sodium 13 / 4
Boron 4 / 0
Potassium 0 / 0
Vanadium 0 / *
Viscosity 40C 83.8 cSt Dyson
Viscosity 100C 13.6 cSt Dyson
SUS Viscosity 210F 70.2 Blackstone
TAN 1.51 / *
Flashpoint 420 / 410
Oxidation 8 / *
Nitration 7 / *
Water (KF - ppm) 937 / 0.0
TBN 9.6 / 11.0
Fuel 214 / *
Soot 0 / *
Glycol/Coolant 0.36 / *
Viscosity Index 167 / *
Sulfate 13 / *
Blackstone Comment:
The TBN for this unused oil was 11.0, which is quite high for an oil intended for use in a gas
engine. The viscosity when checked @ 210ºF, was properly on the SAE 40W range. We have never
seen this oil before, but as nicely as it checks in all tests, we will probably be seeing a lot more of it.
This 10W/40 oil was found to be clean and dry and in serviceable condition.
Iron 3 / 0
Copper 0 / 0
Tin 0 / 0
Lead 0 / 0
Chromium 0 / 0
Nickel 1 / 0
Aluminium 1 / 0
Titanium 0 / 0
Silver 0 / 0
Calcium 1098 / 1143
Magnesium 977 / 969
Zinc 1032 / 905
Barium 5 / 0
Molybdenum 0 / 1
Silicon 3 / 3
Sodium 13 / 4
Boron 4 / 0
Potassium 0 / 0
Vanadium 0 / *
TAN 1.51 / *
Oxidation 8 / *
Nitration 7 / *
TBN 9.6 / 11.0
Fuel 214 / *
Soot 0 / *
Sulfate 13 / *
Blackstone Comment:
