Canadian Tire Corporation Motomaster Supreme 10W30 SM GF-3/4. I have to disagree with the "Odor Normal" as this oil smells bad.
Wear Check comments: The iron level is marginal. There is a moderate concentration of dirt present in the oil. The oil viscosity is lower than typical, possibly indicating the addition of lighter grade oil.code:
Oil Brand: Motomaster
Oil Series: Supreme
Oil SAE J300: 10W40
API SX: SM GF-3/4
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.1
Aluminum Al 0.9
Chromium Cr 0.2
Iron Fe 0.6
Copper Cu 0.2
Lead Pb 0.6
Tin Sn 0.0
Molybdenum Mo 27
Nickel 0.0
Manganese Mn 0.1
Silver Ag 0.3
Titanium Ti 0.1
Potassium K 2.6
Boron B 172
Silicon Si 4.4
Sodium Na 0.0
Calcium Ca 1552
Magnesium Mg 5.7
Phosporus P 446
Zinc Zn 566
Sulfur 2296
Barium Ba 0.1
cST @ 100 C 66.3
cST @ 100 C 10.6
Viscosity Index 148
Water Negative
Appearance Normal
Odor Normal
TAN 1.94
