Zn 906, Si 3, Mo 0, Ag 0, Ni 0, K 3, Na 8, Sn 0, Pb 0, Cu 0, Al 0, Cr 0, Fe 1
Visc 100C = 12.3 cSt.
Particle count was flagged as abnormal. I did have it stored in the cold for a while, and shook the bottle before having it tested, so there may be some additive dropout causing the particles.
10u per mL 1243
15u per mL 225
Thanks to Toromont Cat for this analysis.
I'm not sure about the Na and K since most of the results I've gotten have had similar levels.
Bottle says API SJ, and mentions CF, CG-4, GF-2, but it also says Energy Conserving, and Canadian Tire is not on the list of API licensees, so the label may not be telling the truth. However, lab results make me believe this is a motor oil. It might possibly be Shell Rotella SB 0w30, since I've heard that Shell supplies Canadian Tire.
10u per mL 1243
15u per mL 225
