Hi,
This is Saab Turbo Synthetic Blend 5W-30 oil
which only meets ACEA A1/B1.
Lab is Blackstone labs. This oil is regular
service oil for all Saabs which pre-date 2003
model year. We suspect that this oil is made
by Mobil. Your comments are appreciated.
Thanks in advance.
Component Measured Expected
Aluminum 0 (0)
Chromium 0 (0)
Iron 1 (1)
Copper 0 (0)
Lead 0 (0)
Tin 0 (0)
Molybdenum 0 (0)
Nickel 0 (0)
Manganese 0 (0)
Silver 0 (0)
Titanium 0 (0)
Potassium 0 (0)
Boron 0 (56)
Silicon 4 (19)
Sodium 2 (31)
Calcium 2734 (555)
Magnesium 261 (80)
Phosphorus 1094 (743)
Zinc 1135 (410)
Barium 0 (24)
SUS Vis @ 210 °F 58.7 (56, 63)
Flashpoint 430 °F > 365 °F
TBN 11.0
Blackstone comments:
JAE: The additive group in this oil is sufficiently heavy for use in a diesel. Normally oils used in gas engines don’t run at these levels. Zinc, for instance usually reads at about 900ppm. The oil has typical viscosity for a 5W/30 and was found to be clean and dry. No significant metals present. The TBN was 11.0, high for an oil intended for use in a gas engine. This oil should serve your needs well.
oil analysis
Jae
[ March 29, 2003, 02:08 AM: Message edited by: J ]
Thanks in advance.
Aluminum 0 (0)
Chromium 0 (0)
Iron 1 (1)
Copper 0 (0)
Lead 0 (0)
Tin 0 (0)
Molybdenum 0 (0)
Nickel 0 (0)
Manganese 0 (0)
Silver 0 (0)
Titanium 0 (0)
Potassium 0 (0)
Boron 0 (56)
Silicon 4 (19)
Sodium 2 (31)
Calcium 2734 (555)
Magnesium 261 (80)
Zinc 1135 (410)
Barium 0 (24)
TBN 11.0
oil analysis
Jae
