Originally Posted By: pbm
PS: Every time you change your oil to a different brand you are 'mixing' due to left over in the engine...
And one of the recorded mess ups from mixing that lead to damage of a fleet of vehicles was exactly that scenario...the left over factory fill oil didn't play well with the first oil change, and lost it's cold temperature performance, all the way to room temperature.
My new Ford 2.5 takes 5.7 quarts....I doubt that adding .7 quart of Mobil 1 0w30 AFE ($2 a quart at AZ) to a 5 quart jug of AFE 0w20 would do any harm....it might even improve an already great oil.....It also saves me from buying a single quart of AFE 0w20.
OK, your claim, your proof.
What to you surmise MIGHT be improved in the mix of two licenced lubricants ?
It would seem pretty fruitless to save a dollar and have to put it through the raft of API and ACEA tests so that you could even claim that it "meets SN".
How would/could it improve it, and through what mechanism ?
It COULD just be the magical blend that they lube the gimbals on the hubble telescope, but neither you nor I know that for a fact.
