We just got one of these scooters for my wife, and as I was reading through the owner's manual, I came across the following verbage regarding what motor oil to use:
*From 14F to over 86F, use 10W-30
*From 14F to over 104F, use 10W-40
*From below 50F to over 104F, use 20W-40
*From Below 50F to 122F, use 20W-50
This scooter does not have a common sump where the engine, transmission and clutch all share the same oil.
Now my questions: what does that first quote mean? No HDEO can be used, or only those rated "CD?" This confusing because "CD" is an obsolete service category, and all subsequent service categories can be used in place of "CD."
I've got a lot of Delo 400 15W-40 at my shop, and it would seem perfect in this application, except for this issue. Maybe I should just use GC and let it go at that... or maybe I should use my Harley 20W-50 oil... hmmm.
The other confusing statement is this: "Do not use...oils of a higher quality than specified," yet the specification listed is for "SE, SF or higher."
Maybe I'm just too tired to think this through clearly, but if anyone can decipher this I would greatly appreciate it.
Then, back in the specification section of the manual, it is stated:quote:
Do not use oils with a diesel specification of "CD" or oils of a higher quality than specified. In additions, do not use oils labeled "Energy Conserving II" or higher.
Here are the temperature range/viscosity guidelines:quote:
Recommended oil classification API Service SE, SF type or higher.
