quote:
Originally posted by LargeCarMan:
What blows my thought process out of sinc is that the OEM say's these types of oils will cause some clutch slippage and pre-mature wear?
But apparently thousands use these slippery oils and don't have any problems.
I think you will be hard pressed to find an OEM, be it a bike or oil OEM, that has, or will, state that any oil will cause clutch slippage and pre-mature wear.
Only conventional wisdom, which is often clouded by misconception and myth, would make such a claim.
Now some oil OEM's may well ride on these myths and misconceptions, especially if that OEM has a moto specific rated oil to peddle.
And bike mfg's may also add a disclaimer to their recommendations, on the chance that there could well be an oil that could possibly cause a problem.
As stated, MA rated oils have been certified to meet certain criteria that would show by previous testing that they will more than likely not cause a wet-clutch problem. But these moto specific rated oils are basically provided for the ease of consumer choice.
There are many, many oils on the market that may well pass these moto specific testing procedures, yet are not marketed towards the moto niche.
Conventional wisdom, as ignorant as it often is, has stated that moly will cause a problem in wet clutch bikes. The fact that Redline is an oil that uses very high amounts of moly, yet there are very few, if any, reports of it causing one bit of problem with such machines, is very convincing evidence that the general public consensus on motorcycle engine oils is, for the most part, ignorant.
There will always be those who claim you need to use only MA rated fluid, or risk certain damage or problems. But those folks usualy have some sort of stake in you purchasing MA rated fluids.
Either that, or they are simply passing along misconception and myth.
