Originally Posted By: SatinSilver
Did you see the pics I posted at the top of the page? As mentioned I've used Gumout Regane High Mileage and noticed zero difference after using it. Maybe if I used a double dose it would have made a difference but the directions don't state to do that.
Another reason I've used it is to eliminate pinging in the engine. I don't fill it completely up with the premium. Only for top offs and will do it for a few runs around an oil change. Initial acceleration is much better. People were on my tail and some would raise their hands as if to gesture why I'm accelerating too slow. Not anymore.
The only thing you've proven is pretty much what everyone here already knew. Don't buy c-rap gas from a c-rap station. By from a known TopTier provider and you'll be fine. Running higher octane is only going to cause excessive carbon buildup in the long run which compounds the problem you had already which was again build-up from running c-rap lower detergent fuel. You can claim you can feel it just like I can claim one oil vs. another feels better. They are both unsubstantiated and baseless. Gumout & the like do in fact work or else no one would use them, injectors do get clogged and valves to get dirty from again less than ideal fuel.
Also if your engine pings, you have something else wrong that you need to address. Throwing a higher octane fuel at it is a band aid fix for a bigger issue.
