They also have a product called Maxfilm. Use it on your chain, and it will last longer. I don't have a bike now, but after several 100 thousand miles testing synthetic oils(Amsoil, Mobil1, Castrol,Esso and others), I have found RP to be the best. Also their grease for wheel bearings is great. If you have a temperature gauge, you will probably see a drop in temperature, when you start using it.
