Royal Purple MC Oil
Southern California
Does anyone have experience with Royal Purple motorcycle oil? I'm thinking of using it in a CB1000, and would like to go 4000 miles between changes. Thanks
They also have a product called Maxfilm. Use it on your chain, and it will last longer. I don't have a bike now, but after several 100 thousand miles testing synthetic oils(Amsoil, Mobil1, Castrol,Esso and others), I have found RP to be the best. Also their grease for wheel bearings is great. If you have a temperature gauge, you will probably see a drop in temperature, when you start using it.
