If it was stored indoors I'd go on and run the oil that is in it.
It was stored outside but under a shed and nylon cover.quote:
Manual allows for up to 15w50 due to summer temps in SC, plus due to the considerable amount of slow speed riding and other comments on running the redcap 15w50 I gave it a try. The oil cooler fan has definitely had less of a work out since changing to the Mobil1. However, I am looking to switch to a 5w40 but I haven't been able to find Rotella in my area. What filter would you recommend over OEM?quote:
Originally posted by Arctic388:
wow ! why so heavy oil ? doesnt manual call for 10 W 40 ? since you dont ride much i'd recommend annual changes. of course i'd recommend you use amsoil. also since its out doors even though its covered up, condensation is a big oil killer. if you use the OEM stuff i'd recommend 6 month changes.
No hour meter but my estimate would be 6-8 hrs.quote:
Originally posted by blupupher:
How many hours was that 90 miles, or does it have an hr meter?
