There are as many different 2 stroke oils as there are auto oils. For air cooled, TC apps, a low ash is good, for water cooled TC-W apps, ashless is the ticket, and racing oils are another different breed. Most of the info you seek can be found in MSDS or spec sheets from manufacturers. An entry level 2 stroke lube for , say, a weedeater will be a petroleum base; pretty much what is known as bright stock, a dilutent (kerosene, toluene), a cleaning agent (stoddard solvent) and a dye. Next step up would be a semi synthetic, a mix of synthetic and conventional base, cleaner, dilutent and dye. Synthetics are group III or IV, with a dye, and probably kerosene. There is not as much cleaning agent added, as they burn cleaner. Some racing oils are exotic blends of synthetic and bean oils, like Castrol A747. Others are straight synthetics, and Redline has a group V offering in it's racing/kart formulas. Here are a couple of examples of 2 stroke lubes:
Phillips..
2. COMPOSITION/INFORMATION ON INGREDIENTS
Hydrotreated Distillate, Middle ..C11-25
CAS# 64742-46-7
35.8%
MATERIAL SAFETY DATA SHEET
Injex Pro
Injex Pro
Appearance: Purple
Physical Form: Liquid
Odor: Mild aromatic petroleum
Intended Use: Two-stroke lubricant
Phillips 66 Company
Lubricants Division
P.O. Box 25316
Santa Ana, CA 92799-5376
800-766-0050
Injex Pro
OTHER COMPONENTS (Percentages by weight)
Limits Agency Type
Additives 36.6%
Lubricant Base Oil (Petroleum) 0-20%
Polybutene 10.4%
The base oil for this product can be a mixture of any of the following highly refined petroleum streams:
CAS 64741-88-4; CAS 64741-89-5; CAS 64741-96-4; CAS 64741-97-5; CAS 64742-01-4; CAS 64742-52-5; CAS
64742-53-6; CAS 64742-54-7; CAS 64742-55-8; CAS 64742-56-9; CAS 64742-57-0; CAS 64742-62-7; CAS
64742-63-8; CAS 64742-65-0; CAS 72623-85-9; CAS 72623-86-0; CAS 72623-87-1
Castrol A747 Racing..
SECTION II: PRODUCT/HAZARDOUS INGREDIENT INFORMATION
10-30% Castor Oil [CASRN 8001-79-4]
10-30% Multifunctional blend consisting of ash less
dispersant, antioxidant and additives
[CASRN NA, mixture]
40-70% Proprietary Synthetic Ester [CASRN NA]
Castrol Act-Evo..
10-20% Multi-functional additive blend consisting of
ashless dispersant, anti -oxidant, synthetic
diester, and pour point depressant [CASRN
NA, mixture]
60-100% Severely refined petroleum basestocks ,
petroleum hydrocarbons, and synthetic
hydrocarbons. May contain one or more of the
following CASRN; 64742 -47 -8, 64742-54-7,
64741-95-4, 64741 -88 -4, 9003-29-6
As you look at the individual components, you'll begin to see similarities in 2 stroke oils from different manufacturers. The Castrol Act-Evo, and Lucas Racing 2 cycle are virtual clones of each other. Castrol TTS is Act-Evo with another petroleum distillate pack added. The famed Mobil MX2T is a great oil, but there is little info on it's composition. There is a thread regarding it here on BITOG. A 2 cycle lube has a unique job. Pick the right oil for the right application, and you can have good luck with several of them. Pick the wrong one, and you can have short engine life, ring wear, blowby past the piston ring, scored cylinders, and other issues. For any app requiring TC, try MX2T. For injector apps, Castrol TTS is a fine oil. Redline is very good for very high RPM kart motors. A747 is almost unbeatable for a vintage air cooled motocross machine. Good luck on your search.
