Hi experts,
would like to know, which oil you would prefer for the 20 years old 2-stroke 4-zylinder street racer Suzuki RG500Gamma.
It has a cassette 6-speed gearbox and a wet clutch, 2 crankshafts and a connecting/pilot shaft, their gears and a damper get also the same, but only the flying around oil (but not sure, if they're still in the sump).
I'm installing new steel and friction (non-kork) plates the next days.
I gave the baby all the last 5 years (~20000km) a fully synthetic Mobil 1 (think 15 or 20W50).
I saw these days this very nice page from Bob with additives http://www.bobistheoilguy.com/images/lucas/lucas.htm and the one with the synth vs. non synth gearbox oil http://www.bobistheoilguy.com/gearoiltest.htm and would like to change for cooling reasons!
I have to say, that it is a wellknown problem of the bike,that it has a more or less draging clutch, so hard to find neutral in stand still and also hard to push the lever with the left hand.
Suzuki says in the manual, to use a quality SAE 20W40 multigrade oil.
I ride in temperatures 45-100°F
What should I use?
SAE 20W40
or ATF
or fullsynth
or 80W85
or 80W90
Every help is welcome!
Thanks so far.
Cheers
Carsten (Aachen - Germany)
What should I use?
SAE 20W40
or ATF
or fullsynth
or 80W85
or 80W90
Thanks so far.
Cheers
