I have a '92 Suzuki GSX-R750 with head work cams and a big bore (955cc) kit, aftermarket ignition, flatslides, etc.
The bike has over 100K miles on the motor as it sits, I used to race this bike, but now it is just a street bike.
On the track - airflow was never a problem, the oil in the pan would rarely get over 90C, now I get stuck in stop and go traffic every morning and the temperature climbs and climbs and climbs until I get moving again.
I have a couple of questions. First, the bike now smokes - surely due to worn rings, valve guide seals, etc - but it still runs well, and is not worth rebuilding.
What is an acceptable oil temperature in the pan before I should start worrying about it overheating? I have always thought that about 110C seems too hot - not becuase of any scientific data - it just seems like a big number - knowing that my water cooled bikes rarely ever reach the 100c mark. When it gets there I try to keep it in a high gear, or coast, or turn it off.
Second - what oil would be good for these operating conditions. The bike has a big oil cooler, and does still get revved to 12,500 or 13,000 rpm a few times a week. The factory recommends 10w40. From the factory this bike made about 80hp. now it is over 130.
I used Golden Spectro 10w40 for the first 30-40K miles, then started using the heavier Golden spectro - I think it was 20w50. At around 100K (5 years ago) I started using Mobil1 V-twin 20w50 synthetic.
I live in south florida - do you guys have any better recommendations for oil? Maybe something that smokes less as it burns?
