Hi everyone,
i just bought a 01 kawi ninja 500r,
when every i buy a used car , i usualy put 10% mineral spirits the engine and let it idle for 10mins, then i drain the oil.
put fresh stuff in idle it again for 10 mins, and change the oil and filter one last time.
because this is a wet clutch bike, can i flush the engine, or will i destroy the clutch.
I will only be flushing it during idle, not under load.
i plan to use 20-50 for the flushing so it does not thin too much, and 15-40 during normal use ?
thanks
nik
thanks
nik
