Originally Posted By: car51
Looks very good. I'm running a FL-400S on the Camry for 4-5k then using the two ST 4386 I got while back
Use that filter with confidence
car51, a 96 Corolla with the 1.8 engine that uses the 4967 part # filter, can an FL-400S be used on this engine? What I'm getting at is, the diameter of the filter gasket is not to big for the mounting base, is it?
